the tractor vet
we got it up and running and it has turned out to be a four beer flat rate job doing so It runs great , new key switch and connector a elquicko carb cleaning a readjustment on the points and brake and it runs stops and charges . still need to change hy tran and filter refine the speed control lever to set in the N gate and PUT a new seat on it . Remove the Mule drive and put the blade and chains on . The Sherman and Williams overhaul will come later. Yes i am a happy camper . And now i can pull the steering box off the other 1250 that i had that needed a ton of work and rebuild that at my leisure then make the swap . Ok so here is a question for the brain trust should i keep it yellow and white or do a 2150 rad and cream?????? or is this one of them WHAT EVER FLOATS YOUR BOAT DEAL'S
