the tractor vet
Still getting pieces and parts gather up . Man what a fight . Carb mounting gskt's . I thought i had the correct harness connector for the key switch but someplace i must have used it else where . The key switch and wire ends are the problem of why it does not run . Now in the morning i will run up to and out of the way lawn mower shop that says he has the cab gskt's . and see . The local old I H dealer thought he had them but a bin check said NO . Maybe by this weekend , Fingers crossed it will be running and snow blade on . Then it will NOT SNOW for sure the rest of this year . Then it is onto the deck and fix the rust thru's and center spindle and two new belts. Then i can be like the one neighbor with the postage stamp yard that with a push mower ya could do in 20 min. he takes and hour and a half to mow with a 48 inch rider that sound like a old FOX chopper doing corn . Yea i am thinking dual exhausts with straight pipes. And OH just and FIY the key switch from the I H dealer was a LOT LESS then the internet ones , So more barley pop money can go into the repairs on the cubby.
