892 reversing gear box
Don-Wi
I took the head off the 892 this last weekend and got to looking at the gearbox so I know what I'm in for. does it even have a drain plug? Or do I have to split it to get the old oil out?
No manuals yet but definitely gonna get some soon.
donovan from wisconsin
I got to thinking about this when you needed to get that hydraulic oil out of the 1600 Don. Maybe you need to invest in a little pump that runs off an electric drill or something so you can just drop a hose in to things like this and pump the oil out.
You noticed that too huh? If it doesn't have a drain plug I can easily add one if I need to open it up.
Donovan from wisconsin
There's 2 1/4 pipe plugs somewhere on the front or
side of the gear box. One for checking and filling
and a drain near the bottom. Uses Dextron 3 ATF.
Got your email but after looking at the book it doesn't have what you need.
As far as the oil mine uses 80w90 gear oil but others may be different. A suction gun would work if you just need to change the oil. By the way which corn head did you get with it?
