New Idea 484 round baler question.
I've got an NI 484 round baler and it seems to work really well. Probably my biggest concern is the amount of hay that gets caught up between the belts. The belts appear to be factory (no visible splices) and do have a good bit of wear. The tension adjustments are set to the book. Any thoughts? Has anyone else out there run into this?
I had one and never got too concerned about hay between the belts, just pulled it out ocassionally. But, then again, I traded it
about 25 years ago....
The baler likely cam with endless belts. 95% of owners will replace the endless belt with a laced belt. The main reason is you have to disassemble the baler to put
endless belts back on the baler.
