Still looking for 1924 IHC drill part
Farmallb
Hoping someone knows of a horse and early tractor pulled machinery salvage yard that might have this part. Ive tried MacNairs with no luck
<image src="http://forums.yesterdaystractors.com/photos/mvphoto6377.jpg"/>
I would IF I had it. Im afraid to take one off, as each is pinned by a pin no bigger than a small welding rod. I imagine that the pins are rusted tight into the piece I want and only move in the holes for the pins at each side of the piece I need.
You could drill out the pin if you had too and replace it with a bolt possibly? If not use lots of penetrant or possibly some heat. Patients is the key here
The pin has swiveled on the 2 holes either side of the part I need INSTEAD of inside the part for 93yrs.
I thought I said that the pin was in between bailing wire and the smallest welding rod.
The part is gone. Lost. I don't know where it is. That's why ive been trying to find another part for 4yrs.
Do you have the IH Seeding Machines Parts Catalog? If you have a part number, I might be able to chase something down for you… My e-mail is open.
SadFarmall
