Roll over box replacement blades
chvyhs
New User
I picked up this roll over box and I'm trying to get it back in working order. I haven't been able to locate a replacement blade for it. Anyone know where I can order one? The current blade is 64 3/4" long, 1/2" thick, with 6 bolts. The holes are 12" apart and the outside holes are 2 1/4" from the outer edges of the blade. I have the ability to cut down a blade that's too long. I just need the right hole spacing.
Thanks,
Richard
What isn't it doing for ya? It looks like there's quite a bit of meat left on the blade. I would take a grinder and tune it up
before replacing I think.
It looks like regular bucket cutting edge material in the pics. You can buy it by the foot and drill your own holes. It's a lot
cheaper that way.
(quoted from post at 23:09:48 09/16/18) The blade isn't cutting enough. The body of the box is what's on the ground. Not the blade.
Have you tried loosening the bolts? The holes in the straps are not adjustment slotted but the ones in the blade probably are.
