plans for hydraulic manifold block for inc
Does any one have plans for an adapter block for a super c that
alows one to run lines from the pressure line, on the side of the
reservoir, to an independent set of hydraulic controls, WITHOUT
cuting the steel pressure line from the pump?
I would just cut the lines and braze fittings to the lines and run hydraulic hoses. You can always find a set of pipes from a junk tractor at a later date. There are plenty of donor tractors out there. I have one here out back in fact.I'd probably give it to you if we were closer. Western Colorado.
That is the typical way of doing the conection. If I had all the parts collected to put every thing into operation I would.
I am working at a design application that may take a period of time so that is the reason for looking for an adapter block so I have time to process the adeptation or modify it before full finish.
Hope fully some one may have a drawing for one.
Thank you for your direction, I will keep this option in mind, though.
Wm.
One way to do it is use a by pass block. Goes on the side of the hydraulic unit. Ebay has one listed
