I got a couple extra---where do they go?
Hello,
Well I finally got a conversion kit for my 1968 JD 3020 diesel to convert to a 12 volt system. I ordered one of the kits from Abilene Machine and it appears to be decent. However the instructions are a little vague on what to do with the extra wires. I have included a photo of the wires that I cannot find where they go. I got the alternator wired correctly but on the starter side is where I am having the issue. The extra wires are from what appears to be a newer JD wiring harness. I have one single blue and one single brown, then I have a set of blue wired together and a set of brown wired together. Any ideas where to put these?
The single blue & brown wires plus the double blue & brown wires attach to solenoid post that battery cable attaches to. Did your tractor have the circuit breakers bolted to a plate attached to starter? If so you could re-install circuit breakers attaching single blue & brown wires to them but you'd need to add wires from positive battery cable to power circuit breakers
