John Deere 8300 drill
Gjeffries
New User
Hello
I bought a John Deere 8300 drill. Trying to figure out which setting to use to drill wheat to harvest have no book on it just got it early in the year been planting beans with it
Does anyone have any ideal which gear setting I need to use and which locks to set at thanks for the help
Welcome to YT
By you mentioning setting gears is your drill double-run feed? How long is seed box on your drill? Are the seeding charts missing inside grain box lid?
(quoted from post at 03:43:24 09/19/17)
Welcome to YT
My spacing is 11 wide and I do have a chart but I really don't understand it trying to get 150-180 pounds per acres
I have a picture of it not sure how to post it
(quoted from post at 14:08:15 09/19/17)
Welcome to YT
I hate to sound like B&D, but you really need the manual to understand what chains / sprocket and settings that will ne needed.
I failed to post a phone number, maybe B&D will help me out.
IS your drill a JD 16 hole ten inch spacing drill???? IF it is then it is more than likely what they call a double run type drill. You set the speed and GATES to get your seeding rate. I have done one in 20 years but your manual will show you how IF you get to the correct section. You need to be setting the double run drill not the fluted feed drill. The manual shows both.
