Mike Burgan
New User
I have a 1948 John Deere B with a slipping clutch. It have replaced the: inner and outer clutch facings, the sliding disk drive, the clutch disk and facings (as a unit), and even the fixed clutch disk drive. In order to get the tractor to move, I have had to tightened the three clutch adjusting nuts down until they are about 1/6th of a turn from being fully tightened. As you can see in the attached pictures the whole pulley assembly is sitting away from the tractor body (19/32" away with clutch engaged and 15/32" away when clutch is disengaged. It has been like that for several years, but always had clutch, and the gear was lined up with the first reduction gear, so I was not too worried (maybe I should have been). The tractor made it through the winter pushing snow (north Idaho) but just barely. Now it has trouble just getting up the hill in 2nd gear on its own. Any ideas on what is happening, and what I should check??
<image src="http://forums.yesterdaystractors.com/photos/mvphoto13102.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto13103.jpg"/>
