JD 4230 Steering Box back pressure
hmh fla
Hello, What would cause the Steering Valve/box to have excessive hydraulic back pressure on it? I just put a rebuilt one on the tractor, it immediately started Leaking at the top of the Steering column. Thanks for any advice.
Then that means the valve is not calibrated correctly,, there is an adjustment procedure that must be done correctly,,and it's easy to be off a bit, I do them here and then bench test them to prove them..,,I would be glad to do that for you, not sure what or how you would deal with who set it up,, I would give them a chance to correct it...
Looks like a great set up. I will probably just send it back to them and get another one. Thanks for the help.
That would be best for you,,next time send it to me will be about $380 plus shipping,,I'm not sure what you had in yours,, probably twice that..
Tim, I definitely have more, money in it. I will suggest surely keep you in mind. Enjoyed talking with you. They a ede sending.Me another one.
