JD MT removing rock shaft for inspection
marlin54
I have a 1950 JD MT and trying to remove the rock shaft but the 2 rods that come fro the control levers are holding it from
coming off and the other end up front has only a hole to look in and not big enough to get tools in it to unclip it there. Does
and one have an idea if I need to remove the front cover to unhook the rods? what is best way to get rock shaft off to see the
piston and check everything out?..thanks
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">what is best way to get rock shaft off[/i:654c4848f0][/b:654c4848f0]</font>"
Reviewed the [b:654c4848f0]SERVICE MANUAL FOR JOHN DEERE DEALERS MODEL "MT" TRACTOR (SM 12-1-49)[/b:654c4848f0] in the [b:654c4848f0]Dual Touch-O-Matic System[/b:654c4848f0] section under the [b:654c4848f0]Group 15 VALVE HOUSING AND ROCK SHAFT HOUSING[/b:654c4848f0] heading under the [b:654c4848f0]REMOVAL[/b:654c4848f0] topic on page 180-15-2.
Take a look at the information below.
a280349.jpg" width="650"
Hope this helps.
Thanks James for your help. This weekend I will hopefully get it apart. I have a John Deere parts catalog that shows the exploded views but does not show the pictures and the procedure. with what you said it makes sense. Its so rusty in there I could not see the clips. now I know . thanks again for your help.
