Stripped Threads
NCmau
This may not be related to MF machines but since I am using a lawnmower deck mounted in front of my loader bucket, I hope it will slide.
This deck is powered by a 12HP BS (aluminum block). The 1” hole for the muffler pipe is stripped. There are no other fastening holes for a muffler pipe. I tried to rethread the hole with a tap, but it just doesn’t hold.
I like to hear some suggestions. I was thinking of plumber rope or muffler putty kit… but maybe there are better solutions.
Are there enough threads left in the block for you to wrap Al foil around the muffler
threads.
If so, wrap three or four wraps then try to screw the muffler into the block.
Might be a muffler seal out there, coat it, screw it in,, then let it set and harden.
I doubt that it can be repaired but if it can you need what is called a short taper pipe tap. They are used in shallow holes. You can cut off a regular tap with a disc cutting wheel. A regular pipe tap needs to go in about 3/4 of the thread length for a standard pipe fitting. It is more detailed than I can get into here.
Find the best NAPA store [ they are various and different ] and go ask the oldest old guy for his advice.
(quoted from post at 17:51:47 03/30/15) Are there enough threads left in the block for you to wrap Al foil around the muffler
threads.
There are few threads but not enough to hold it when running. I guess it wouldn't hurt to use, at first, aluminum foil and muffler seal as you suggested. If that doesn't work then I move to plan B.
Thanks.
On my 67 10 horse briggs my muffler was loose where it threaded in so I got a big nut from an electrical supply house and wrapped tin foil around the threaded pipe going into the muffler. After I threaded it in I cinched it down with the big nut and it worked. That's been 3 years ago.
(quoted from post at 10:06:04 04/10/15) On my 67 10 horse briggs my muffler was loose where it threaded in so I got a big nut from an electrical supply house and wrapped tin foil around the threaded pipe going into the muffler. After I threaded it in I cinched it down with the big nut and it worked. That's been 3 years ago.
Yes that's a good option. I used that years ago with a 5hp and it worked well. On this one, however, there are very few threads left and I am not sure the nut is going to work. But I will give it a try when I get back to the project. Thanks.
(quoted from post at 07:25:22 04/03/15) Stick it in there as best you can, then braze it.
Braze aluminum? Please tell me how to do that.
if there is enough metal, the best solution would be to go up one size and use a hex bushing. Welding would probably damage things unless the head was removed, stripped and pre-heated..
(quoted from post at 07:52:15 03/30/15) This may not be related to MF machines but since I am using a lawnmower deck mounted in front of my loader bucket, I hope it will slide.
Goto Harbor Freight. They have an aluminum rod that will flow with a map gas torch. It is awesome stuff.
(quoted from post at 05:28:53 04/20/15)
Goto Harbor Freight. They have an aluminum rod that will flow with a map gas torch. It is awesome stuff.[/quote]
Just like solder. You can us a propane torch. Wire brush the area. Heat with the torch. The rod melts before the base aluminum gets to hot. See a demo on youtube at;
https://www.youtube.com/watch?v=aiThO-UQIWE
I use Map Gas . just like Propane but hotter. You can even plug the hole, re drill and tap. Practice on junk first.
Good luck.
Good luck.[/quote]
I saw the video. Definitely good stuff. Thanks for the tip.
