balsabones
Hi y'all, I'm new to the forum but read it all the time. I'm asking this question in the MF board because I have a 96 TAFE 35DI with 345 hours. I have owned it for 11yrs and found out that the MF 135 is pretty much interchangeable with parts. It has a Simpson S 324 engine, 3 cylinder, with a Mico fuel pump. It has never skipped a beat since I have owned it. I went to crank it today and it cranked right up but revved high ramp and ran for about 10 seconds then died. Now it won't crank at all. I loosened the injector lines going to the engine from the pump and it's pumping fuel. When I hold the throttle wide open and turn it over, fuel drips from the over flow tube. I'm mechanically inclined and build my own car engines so I can fix whatever is wrong if I could get some help diagnosing what is wrong. Any help will be appreciated. Thank y'all in advance.
