Just curious about some Massey production history
Did Massey Ferguson ever produce a hydro
or torque converter type transmission on
agriculture tractors.
Case had the case-o-matic, Ford made the
SOS, and International made some hydro
tractors.
(quoted from post at 08:36:07 02/21/18) Did Massey Ferguson ever produce a hydro
tractors.
MF had a Multi-Power feature. You could do a few searches online and find some more info on it.
The MF multi-power is a shift on the go high/low range, other makes of tractors have something very similar. Some call it dual power, or something along those lines. Some of the MF industrial tractors came with the instant reverse, torque converter transmission. You have a pedal to push on to make it go either forward, or reverse (shuttle shift) instead of having to use a hand shift lever.
Massey-Harris did have a 101 and a smaller Pacer or Pony with torque convertors for testing, not sure if they made production. Several MF industrial models used the four speed torque convertor ptfarmer mentioned, I had a forklift with it, brother has it now.
Thanks for the info
I have 50a with the torque converter and I was curious if Massey ever produced other types of hydraulic transmissions.
