MASSEY FERGUSON 231 DIESEL
ARTILLERY
My M/F 231 Diesel Tractor seems to only Start when It wants to. CLICKS 3,4,5, Times or 16,17,18,etc. Times then starts. ALWAYS Starts. Solenoid and Starter just fine. I've been told there is an IGNITION ASSIST or STARTING BOOSTER (I may have the Name of Part Wrong.) Kit or Link available. Do YOU know the Proper Name of Part I'm referencing and where I may obtain one ? THANKS.
I have had the Starter checked (by a very competent Shop) and I had a NEW solenoid installed (even though They said mine was Good). I've been told about this Start-Assist Kit ( Not sure that I am identifying it properly)is available for John Deere and other tractors. Seems to be made for a reason. If You have any information regarding such or other suggestions for My M/F 231, I would be appreciative. THANKS !
What about a STARTER ASSIST RELAY ? Saw a STARTER FIX KIT on the Internet. Do You know anything about these? THANKS !
You can check voltage at starter solenoid with voltmeter when key switch is turned to start position,should be 12 volt's!You may have a bad start switch or broken or almost broken wire's from switch or bad connection in start circuit!Be worth checking,might be one of those!
