I bought a remote hydraulic kit with valves lined fittings gas etc fron Steiner. My tractor just had the single remote on it and I wanted the two line hook up so I could raise the disc wheels off the ground. Long story short. I put the valve on tonight. I hooked up the disc and after awhile I fi ally got the disc to raise and lower. It would take about 45 seconds to raise. When I got done dishing. I left the tractor running and shifted the valve back over to use 3 point. I went and done some things with the 3 point and then came back over to hook up the disc to do my other garden and now I'm not getting no flow out of the remotes. I unhooked the lines and just put a fitting in the remotes and I'm not getting no flow no matter what position the valve is in. The 3 point still works fine. What did I break.
