MF205 to 35 marriage
Phil Tibbetts
I have a MF205 with a rebuilt motor (Perkins Diesel)that is not of a lot of use to me with the reverse-o-matic drive. No 3PH but has PTO. How much trouble would it be to put a regular 35 or 203 transmission and rear end behind the engine and what rear section would fit with the least hassle?
if you have the 35 from the bell housing, and back with live pto all you need for the 3.152 engine is the 2 stage flywheel. It should all bolt up, are you using the 205 front axle support, axle, and sheet metal?
I'd like to use all of the 205 I could as it is in good condition. I've had it for almost 20 years. It had a loader on it when I bought it with a stuck motor. Sold the loader for more than I paid for the whole thing because I had other tractors with loaders, it but I regret it now. I completely rebuilt the motor and fixed everything I found wrong with the tractor.
