MF 35 hydraulic pump - control valve - of ring retainer
Hi all I'm replacing the control valve in the pump and need to remove the o ring retainer (item 7) to.replace the orings and the sealing washer.
How do I go about this I've tried putting some wire in to pull it out but won't move?
Thanks.
I.thought that also but the other end you can only see the lip of the sealing washer the put is part of the housing so I'm not sure
