My 1964 MF 135 diesel starting using oil heavily and putting out blue smoke recently. It is using at least a quart of oil per tank of diesel, maybe more. It went from not using any oil to using a lot all at once. I do not believe the tractor has overheated, oil pressure is 40+ psi, compression checked out good, and there is no blow-by when you remove the oil cap. Hour gauge was broken when I got the tractor so I have no idea how many hours it has. I've put about 5 to 6 hundred hours on it since I bought it in 2012.
I took it to a mechanic I trust and he thinks it needs a rebuild. He says for $2000 he can do a partial rebuild (replace pistons), but would prefer to do a total overhaul (valves, re-machine head, and crankshaft if warranted) at a cost of $4500.
Other than the blue oil consumption this is a good tractor. Since purchasing it I've replaced/rebuilt a lot of the components (electrical, hydraulics, starter, steering, radiator, generator, tires, spindles, etc.) and done the routine maintenance. I hate unplanned downtime and keep my equipment well maintained.
With all that said is there any possible cause for the oil consumption other than bad piston oil rings? I'd hate to pay for a rebuild when the cause is something cheaper. A scrap yard will give me $1200 for the tractor. I'm having a hard time justifying the repair costs and am considering walking away from it but sure hate to lose the capability.
