u carb float
jr1983
I have a tsx 87 carb on my utu. It needs a float. I'm having trouble identifying one for an 87. Does anybody have a schebler part number for one or a few other carb numbers that use the same float? Thanks
stiener tractor parts should be able to identify the float and part# they have most of the parts iv'e ever needed for the m.s. carbs on the continental flathead engines. their phone# is 1-800-link_disallowed and when you call jr. request a cataloque. hope this helps. john
good morning jr. try stiener tractor parts they have most of the carb parts for m.s. carbs I use them for parts on the continental flathead engines in Lincoln welders their phone# is 1-800-link_disallowed and ask for a catalouqe when you call they are located in Michigan. hope this helps jr. john.
(quoted from post at 03:37:02 09/09/17) I have a tsx 87 carb on my utu. It needs a float. I'm having trouble identifying one for an 87. Does anybody have a schebler part number for one or a few other carb numbers that use the same float? Thanks
good morning jr. I use stiener tractor parts for m.s.carb parts they should have it in stock their phone# is 1-800-link_disallowed the Lincoln welders with the flathead continental engins use them and when you call ask for a catalouqe. hope this helps. john
