Dragged home aa couple more MM's. One is a M5 diesel with 3 point for rebuild. Other is what I thought it was a Jetstar 3 industrial diesel. It was in a fire and middle of tag melted. Has wide with normal spindles. Back has 15 x 30 rims and odd looking hubs. No pto and no drawbar. It had loader so reservoir was in loader frame. Has big cast Vickers pump. Has power steering pump on cast side cover.No torque but shuttle shift. Motor is 206 diesel with Roosa system. Dash like a U302 what's left of it. Has different brake lock setup. Rear end and transmission as well as shuttle look good inside. Casting number the same as jet 3. Motor has been bored 20 over. Has all correct diesel components except crankcase has a gas model part number so starter and flywheel appear gas.
My best guess it was originally a diesel and crankcase got damaged and a gas was used instead. Had bung in governor hole. Any input. Not planning on posting pictures as it is quite damaged.
