TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Utu front end cover
jr1983
01-12-2018 05:24:21
What do you do for a replacement on the top cover for the front end of a UTU? Agco pn UT5800A. I am in the rust belt and all five of the u front ends I have the top cover is rotted through. Makes it hard to keep water out. Do you make a new one or are they available some where? I have not tried agco as its an hour drive to the nearest one.
jr1983
01-17-2018 19:25:35
 Re: Utu front end cover in reply to jr1983, 01-12-2018 05:24:21
My email is open and I would appreciate a PDF greatly. I done see where your contact is open.
jr1983
01-17-2018 19:18:55
jr1983
01-14-2018 19:51:21
This looks absolutely awesome. Thank you very much. I am not a sheet metal expert but I'm pretty sure I can get it done from this. Thanks again.
wgm
01-14-2018 19:30:27
I made a new cover for my UB using 14ga galvanized iron.
UB-ToMMy
01-14-2018 15:32:49
Years ago I had a pedestal cover made for my UB. I made a drawing from the original cover and gave the drawing and the original cover to the sheet metal place to make. I must have put the holes in it later using the original part since the drawing doesn't show any holes.
UB-ToMMy
01-17-2018 18:16:26
 Re: Utu front end cover in reply to UB-ToMMy, 01-14-2018 15:32:49
Didn't realize the copy would show up so blurry. If you need a better copy, email me and I'll send you a PDF.
jr1983
01-12-2018 05:41:32
Guess I should add I have never had one apart with enough left to use it as a design if I need to fabricate one.
kevin moschenrose
01-12-2018 19:42:37
 Re: Utu front end cover in reply to jr1983, 01-12-2018 05:41:32
I will have to look out in my parts box but I think I have a good one. I can check tomorrow and see.
F-MM
01-12-2018 05:55:06
Our 50 utu had one of those thin plates on it that was all rusted out too and it had allowed water to run down inside and freeze and that split the casting. I have a non running 51 utu so I switched front ends on the two and realized that one had a much heavier plate for a cover, like maybe 1/4" metal. It is a little bit different too as I recall it extends out a little further where the hood latch hooks down but I made it work and look original. You could probably make one but like you said, you need a pattern but you could try drawing a cardboard one first to cover the area.
jwuertz
01-12-2018 06:44:52
 Re: Utu front end cover in reply to F-MM, 01-12-2018 05:55:06
If I remember correctly Welters in Missouri had them for sale.
Scout2008
01-12-2018 10:17:25
 Re: Utu front end cover in reply to jwuertz, 01-12-2018 06:44:52
JWuertz, please email me. I have a couple questions for you.
