Starting 670 LPG
I have a MM 670 Super LPG, and it will not start. It acts as it is not getting gas. If I give it a whiff of starting fluid, it will start right up. Question is , is there a value that opens on a suction of air when you hit the starter? Thanks for any help.
should have a primer button on the evaporator valve that acts like a choke. on my 706 or g1000 I hold it until I hear a bubble sound in breather. I assume 670 is set up same. Be sure you are starting on vapor. Can't really flood them, if you get to much in it will clear out after a little cranking.
How long since last time it was run? I had one a while back that I had to disassemble regulator and carburetor and give both a thorough cleaning.
this one has a choke like on a gas engine..It just seems that it has to have something that when you go to start it that something allows gas to get to the carb.It has Bosch fuel system.
