minniemo705
So I think this is still coming down to this new water pump. Everything else seems right but water is still disappearing. It stays cool for a bit and then all of a sudden it starts to get warm. Hard to explain, it's just that at a certain length of time the temp goes up. So I just started it and watched. There is water leaking out of this new pump some where, can't really tell where but it from there, and it seems enough must leak out and then it starts getting hot. Can't see it while in the cab cause it's dripping directly under the center of the tractor. But it seems right cause the tractor stays cool while working it till enough must leak out. Just is crazy cause the leak doesn't look like much, but? Either way I'm getting a new pump, but not from the same place.
