LOOKING FOR A PART FOR THE MM M5
lenray
There is a piece that sits in front of the radiator and behind that front bumper and the radiator screen sits on it. It has ears on each side that the front side panel bolts to. There are four large bolts that bolt it to the MM M5....Don't know what it is called. Would like to buy one. Thank you
lenray here's a pic of the one on my m5 while I was doing the winter rebuild.
I have couple. The front axle plate goes between it and front support. Looks to be 5/8 plate. On radiator I have one that needs top tank repair. Don't know about core part.
Thanks fellas for the info. and pics--much appreciated. Also --the tractor turns to the right easier than it turns to the left. Any ideas on why that would be the case and is there a way to fix that issue???
thanks
You might be able to cure the steering by adjustment. You need to get a shop manual to do this. The situation is caused by ware or maladjustment. If adjusting doesn't help parts may need to be replaced, however I have my own cure to improve the steering on MM pre hydrostatic steering systems. But I would have to have the unit here in the shop. I also have Shop Manuals to cover all MM tractors. $35
MMDEL
swmolines----thanks for the info. there are two washers that have one side ground off and one spacer bar about 5 inches long. I can't remember if the washers are on the top or the bottom or if the spacer bar is on the top or the bottom. Looking for help.....
