CAN'T SHUT DOWN MM M5 DIESEL
lenray
More questions on this new to me tractor. The only way I can shut the motor off is to put it into the lowest idle position and then put it in gear and let out on the clutch to STALL the motor.
There is a push pull button on the dash that goes down to the injector pump, but it doesn't do any good for a shutdown.
Surely a guy doesn't have to stall the engine to shutdown..
Thanks for any help....
Left side of dash between oil pressure gauge and tach should be shut off button,pull out and hold till engine stops push in to run.
Take cover off side of pump where cable connects to. Two screws. There is shut off rod that pulls governor rod back to shut off fuel.
