JUST also want to say thanks for you great folks and your willingness to help.
Got into the brakes today...The pin on the inside that goes thru those two adjuster fittings had come out and was laying in the bottom of the brake area..
The adjuster rod with the clevis--where the pins goes and the other rounded end that is on the outside of the brake pedal----That assembly is really frozen together---RUST.
Any chance of getting a new one or a used one that is freely adjustable???
Also the adjuster only goes to the outside brake pedal--SO if I want to make a sharp left turn and use that inside pedal---HOW does that work without any thing going to that pedal????
Thank you len in michigan
