Need a brake part for the MM M5
lenray
THIS part is about 7-8 inches long. A clevis end goes into the brake assembly and then a threaded rod that goes into a machined part that is rounded on one end and a big nut on the other end that goes to the brake pedal. This is for the brake adjustment--it is a three piece assembly. Have a feeler out, but not sure he has one. Looking to buy one or two.
Thank you len strouse clare, michigan [email protected]
If don't come up with anything MSC78701927 is clevis/rod that's 7 inches long. Has no threads but can be threaded to 3/8-24. I did this on H Farmall Made new nuts too in shop I work at. Have lathes and mills. Couple are CNC. May have some that I will part with but going off for next 8-10 days.
