Why is the pto lever not working
Heres the lever
If that's an R, it does not turn, it pulls (out or pushes in) to engage. I am thinking the gears have to line up to engage too.
Correct. The lever pushes in to engage the PTO.
A way to check that it's not stuck or rusted is, WITH THE TRACTOR SHUT OFF, put pressure on the lever and with the other hand reach down and turn the PTO shaft. When the gears line up the lever should go in.
Otherwise, with the tractor running, put pressure on the lever, and GENTLY bump the clutch lever a couple times. It should engage.
