3PT Settles down over night. My first thought is cylinder piston seals. That is not as easy as it first appears. Is there some adjustment that can cure this? THANKS
The spool valves might be out of adjustment. That isnt easy either. I believe you might be able to check it on the tractor but I wouldn't recommend adjusting them that way. The proper procedure is removal of the valve body and go from there per the manual instructions. I did adjust them on a 5 Star I had, that had no hydraulics. It was more than a pain but I managed to get it to work.
