Rtu axle gasket
montidale
What are the odds of finding two gaskets that go between the transmission case and the axle housing for an RTU? I suppose I could try and make a
couple up. I dont think theyre real critical. It would just be a lot easier if I can find a couple.
Im betting you might be better off making them. If you do happen to find some new old stock ones I bet they might have shrunk some and wouldnt fit properly.
If you find some and they did shrink, hold them under the faucet with warm water and massage a little bit. They will fit like new and not shrink like you would think, and they dry quickly.
An AGCO dealer should be able to tell you if they are still available. And if not, some dealers have an account with Parts Depot or some similar place that MAY have NOS ones on hand.
I gave Walters a call and gave them a list of all the gaskets and seals I was looking for. Lois put a lot of time into finding what they had. She was able
to find the seals I needed but a couple of gaskets were not available. Lois put a lot of effort in to finding my parts. You dont run across parts people
like that much anymore.
