Walkinfuss
Can use some more help. The original MM volt meter does not work. I replaced it with a new meter, however the new meter will not allow the engine to crank or star when I jump the starter. Tried a second new meter the same. Put the original meter back in and it starts every time, just no meter operation.
When I ohm the old meter out, its a complete circuit. The new meters are open? The new meters read the voltage when I turn the key, just will not allow the motor to turn over of start???
Tried reversing polarity with no success? Both are new Bosch gauges. Any ideas? Thanks
