UTU hydraulic pump
jr1983
I have a UTU with a leaking hydraulic pump. The fluid is spraying out between the plate that the pressure and return lines thread into and the next section. Im told there is a Quad ring in there. Does anybody have a part number or a size?
call Welters, get a gasket and O-rings, 417-498-6496 When you
get it repaired, dont hold the valve past the sroke
