GTB 5.9 Cummins swap
Gregkoch
New User
I'm doing a first gen 5.9 cummings swap in my 1954 GTB. I'm trying to find a trans adapter plate. I was told the m670 has the same Trans bolt pattern.
(quoted from post at 19:23:32 10/29/23) I'm doing a first gen 5.9 cummings swap in my 1954 GTB. I'm trying to find a trans adapter plate. I was told the m670 has the same Trans bolt pattern.
I think that If you do not like the MM engine, maybe a big block is better sizewise, a Cummins 505 (8.3L) should be close in size to the GTBD Block. Or maybe, even an L10 or a NA855 would fit right in there. But you can do as you want, I just think it will look like a baby engine in there.
(quoted from post at 19:23:32 10/29/23) I'm doing a first gen 5.9 cummings swap in my 1954 GTB. I'm trying to find a trans adapter plate. I was told the m670 has the same Trans bolt pattern.[/quot
Here is a plate
https://www.facebook.com/marketplace/item/302390779289368/?ref=search&referral_code=null&referral_story_type=post
