TraktorFreunde
Thanks in advance for your thoughts. I want to drain the coolant from the system, but I've got two problems. One, there is not drain on the radiator....I don't know if maybe it's some newer chinese one or something, but easy enough to get around by removing the lower hose.
Two, the drain on the block is locked up.
So, is the best course of action to get that block drain off and hopefully not screw something up there or is there another way to drain everything out?
Thanks again.
Thanks again.
