Blair(ont)
New User
My starter is just spinning. I was sure it was the starter I think. Removed it from tractor and have on bench. Using a battery charger
with 6 volt to test, it was barely spinning before but with a little oil on bearing and clean up I have it spinning good now. But my
question is the gear is still not popping up and down. This is were I need help to understand what I should be looking for on the bench
before I try it back on tractor. Also I think I read somewhere you should not oil shaft, is this true? Thanks
Blair
Blair
