Switchflicker
After having the radiator cleaned and repaired, I discovered that there was no thermostat.
I now have a 'new and improved' thermostat model #A-B2NN8575A. I'm fairly sure that I install it with the copper capsule (that has the stamp for 180 on it and the spring around the capsule) towards the engine. Is is this correct?
Also, I have a couple of gallons of DEXCOOL on the shelf. Is there a good reason that I should not use DEXCOOL?
As always thanks for your collective help
Stan
Stan
