Hello,
I'm ordering other parts so thought I'd get these at the same time. I'm missing one complete bolt and nut from one front wheel hub and a second one broke or twisted off when someone took off the nut.
I tried pounding out the broken bolt, but did not pound too hard. It looks like a separate bolt per the parts diagram, rather than welded on the hub, as it does have a part number. I presume the bolts are like carriage bolts - I could not tell from the parts diagram and it was not stated.
So any tips on getting that broken bolt out?
Also, as I did not jack it up yet, will the wheel just slide off the bolts once I remove all nuts?
thank you
thank you
