12 volt question
AudioFreq
New User
Hello all.
I was a heli mechanic in the navy so I have a 'decent' understanding of tools and mechanical repairs.
BUT.. I have came into the ownership of a 9N.. probably 1950+.
I was told by the P/O that this one had a 12 volt conversion but it started dieing after about 45 minutes. I did some research on the web and found that it might be the coil.
I went and got a 12V generic coil and installed it.
I have been very careful not to leave the ignition on at all when it is not running and it has started doing the die-after-it-is-warm thing again.
I read the article here about 12V conversions (ty for that). However, the article mentions using/retaining a 6 Volt coil.
I presumed mine was a 12v (when I did the replacement last fall) so that is what I purchased and installed... I also I noticed no ballast resistor on the wire to the ignition as I replaced the coil. This and a lot of ignorance about the 9N lead me to think I was doing fine installing a 12 volt coil.
I guess my questions are:
A) Did I do the right thing installing a 12Volt coil?
B) Does a 12 volt setup with a 12 volt coil need a ballast resistor, if so which one or which value/rating do I use?
C) Is the point gap also .15 for the 9N?
Thank you in advance for this free forum to ask for help and your time.
AF
With a 12 volt conversion and a 12 volt coil - you still need the OEM ballast resistor to keep from overheating the coil. Witha 12 volt conversion and a 6 volt coil you need the OEM ballast resistor plus a step down resistor. The point gap on the front mount dist is .015.
(quoted from post at 15:13:13 06/28/10) Hello all.
AF
ou say, "generic coil" which conjures up in my mind, a round can coil such as would have been on the side mount 8Ns, and you also say 9N, 1950+, which can't be, because 9Ns ended production in 1947.
If you have a later side mount 8N with a round can coil, then there is a good chance that what you were sold as a "12v coil" is supposed to be used with a ballast resistor. There are a few coils that can be used on 12volts without a ballast resistor, the IC-14SB being one for sure and I believe also the CarQuest #26321 & BWD E40. There are likely a few more, but most of the coils sold as "12v coils" actually are intended to be used with a ballast resistor & need one.
Thank you for the fast reply!
Aha! My bad it says 8N-B right on it.
Memory here is not so great, apparently.
Obviously, I really do not know a lot about this one.
This is where I messed up.. the new one says "resistor required", but I saw no resistor on the tractor and put it on anyhow.
I think I can find one of the resistors you listed but do you think I will need a new coil again?
image of the coil/distributor is enclosed. Maybe we can identify this one's year as well.
9N 1939 to 1942. 2N 1942 to 1947. 8N 1948 to 1952. The 9N and 2N both have 3 speed trannys and the 8N a 4 speed.
So what ship where you on and when. I was on the JFK from around 1877 or 78 till 1980 when got out.
Now to your problem. If your is a front mount distributor which 9N and 2N and early 8Ns are then they do not really make a true 12 volt coil and you will need to do as H Cooke said
(quoted from post at 15:08:57 06/28/10) 9N 1939 to 1942. 2N 1942 to 1947. 8N 1948 to 1952. The 9N and 2N both have 3 speed trannys and the 8N a 4 speed.
103 years is simply TOO long to be on the JFK!! ^^
I was land based in Texas, billet # 8215 Search and Rescue.. I did land on the Lex once in the gulf for a medivac but I went EAOS in '85 rather than go to sea for three years. ;)
I am hoping the picture helps you guys determine what the heck I am working on :)
(quoted from post at 16:06:07 06/28/10) Thank you for the fast reply!
I didn't list resistors. I listed coils that do not require a resistor. Fair chance the coil has permanent damage from heat, but you might get lucky and just add a resistor to your existing coil....just a ~$5 gamble.
Thanks again, JMOR.
Yea I meant to type 'resistor-less coils'.
I found a supposed O'Reilly counterpart to that Carquest E40 coil you mentioned.
They stated their number as 2-5025.
26.99 for house brand.
33.99 for a Borg-Warner.
*This was a direct cross reference by telephone and the chap at O'Reillys did not know what it really was ballast-wise.
I guess I can look at the O'Reilly coil and see if it says 'external resistor required'?
I hate to kill another one.
AF
Since you have a side dist engine, forget everything I said -- gap for the side dist is .025.
.025 it is. :)
Ok then:
Installed the new resistor-less coil this morning and by golly after about 45 minutes... it started surging and wanting to die so I decided to stop.
I am thinking the carburetor needs adjusting since it only runs with the choke pulled all the way?
To wit:
A previous issue was that it was not getting enough gas (as in drip-drip off the fuel line at the carb.. so last Fall I drained the tank and got some FOD out of the petcock assembly. I believe I have the fuel starvation issue resolved since it streams out very well now at the carb.
Went to a website and got data on adjusting the carb (noticed that the choke was closed) and nothing even close to the suggestions would work! I returned carb screws to where they were and I have been running it this way since and till recently it would do 'ok' (I have 2 acres and could do half of it.. wait a bit then finish the other half).
I presume this was a 'fix' for some unknown-to-me issue (running the tractor with the choke closed [pulled] all the way)? :?:
Ready to work on it, I just need some pointers since it was all but a basket case which barely ran when i got it.
I have noticed the rear exhaust gasket is leaking as well and I should be ordering that promptly.
I will add that once it starts surging... If I then turn off the PTO it seems to idle fine.
just found this:
'If you have a new round can coil for your 8N and it does not say BAT and DIST on the top of it, just remember, for a POSITIVE GROUND tractor, it's Positive Plus to Points, (PPP) the .+. wire goes to the distributor. Hooking it up backwards reverses the polarity & costs you about 25% of spark efficiency.'
Would my 12v conversion be negative or positive ground?
But I have had about 1 hour 20 minutes of total run time, today.
Running for less time that it ran before I put in the new coil, now (15 minutes).
Perhaps I am not to connect '+' to the ignition switch?
If you're using an alternator - It is most likely a negative ground. Just to be sure look at your battery posts. Non insulated flat braid cable going to the frame of the tractor means it's a negative ground.
thanks, DollarBill
I does have an alternator but there is a normal automotive type insulat4ed ground going from the battery negative post to the frame.
If that is a 'Negative Ground' I can presume that the '+' post of the coil does go to the ignition switch, then?
My new coil is installed correctly, then.
whew..
:/ now onto why it might still be dieing after 20 minutes of use.
(quoted from post at 22:20:02 06/30/10)
(quoted from post at 05:10:58 06/30/10)
whew..
>>bump (sigh)
wow.. ok then.
I guess I can drive it for 20 minutes and whine about it to anyone that asks why I get off of it after 20 minutes.
At some point, one has to ask themselves: "DO I just get rid of this since I cannot get much help online".
I feel like it is a glorified Briggs engine.. It came with the farm we bought. I just do not know anything about its' maintenance history and why it ended up tuned the way it is tuned.
I have a new 60" Deere mower deck for it (2300.00), two blades and a grass sweeper. It also has two brand new rear tires.
I need something which will mow the entire yard in one afternoon.
anyone interested in this relic?
Located in Central MO.
AudioFreq
A search of the archives turned up these troubleshooting steps which may fit your problem.
[color=darkblue:c9be766b80][b:c9be766b80]Runs for about 15-minutes and quits:[/b:c9be766b80][/color:c9be766b80] Restarts after about 30-minutes cool down = BAD IGNITION SWITCH, jumper across switch to test, and if problem goes away, replace ignition switch.
[b:c9be766b80][color=darkblue:c9be766b80]Runs for about 30-minutes and quits:[/color:c9be766b80][/b:c9be766b80] Restarts after 1-hour cool down = BAD IGNITION COIL, replace it. Next time it does this, check quickly for spark. Get an old plug, open the gap to 3/16, ground it to a rust & paint free spot on the head, turn the key on & crank the engine. You have three possibilities: no spark, weak and/or intermittent yellow spark, or a bright blue spark.
Sorry for not responding but I'm not the best when it comes to electrical problems and I have no experience with 12 volt conversions.
Run it until it quits and then check the color of your spark as indicated above.
Don't give up - You can figure it out. Just post back with your results for more help. You may have a faulty coil even though it is brand new. Tell us what the spark looks like when it quits.
