I have a 1950? 8N and noticed a small crack in the engine block. The crack is on the top right corner of the block if you are looking at the engine from the manifold side. The crack is about 3/4" down from where the head meets the block and appears to be about 1" long. It runs horizontal from the area of the exhaust manifold towards the front of the engine. There is a small amount of antifreeze that seeps from this crack. Can this be fixed? If it can be fixed, how do I go about making that repair. I have also noticed a lock of power when the tractor is under heavy load running my mowing deck in tall grass. As soon as I disengage the deck the tractor runs fine. Could this crack cause the loss of power too?
Any help would be appreciated.
Thanks
Ken
Thanks
Ken
