We are in the middle of completing the engine rebuild on our Oliver 1800 C.
Yesterday we finished putting the rocker arms and valve cover on, then we installed a new clutch, pto damper, thrust bearing, and a new coupler sprocket nut. We then dropped the engine in the tub.
Today I headed to the shopt and started attaching the remainer of the items needed. When I got to the clutch there was a problem. When I attached the clutch pedal to the actuator arm the pedal was bottomed out. I removed the connector and tried to move the clutch manually and could not.
What did I do wrong? We are almost done with this project and need to be DONE. Any suggestions that might help us?
Jim
Jim
