49' Oliver 77 RC - brake bands - need advice
JBart
I contacted YT as I get most of my parts from here, and they advised me to post in here. I need to replace the brake bands and can't find them anywhere. I'm I'm PA. Does anyone have any info, or advice.
Thank you.
(quoted from post at 15:43:03 09/15/17) I contacted YT as I get most of my parts from here, and they advised me to post in here. I need to replace the brake bands and can't find them anywhere. I'm I'm PA. Does anyone have any info, or advice.
Thank you.
If they're not destroyed you should be able to find a place nearby to reline them or you may be able to by the material yourself. I would call Korves.
The bands can be relined. There is a company in Mars, PA that will reline the brake bands. They primarily do overhead crane brakes but will help some of us old tractor jockeys out. They bond the lining on. You can also buy the lining and rivet it on the bands too. That takes a special punch which can be found. Google around and you can find them. Good luck.
The company in Mars, PA is Industrial Brake Company. Their number is 800-466-1905. Check out their website.
