PSB pump again
Olliejunkie
Worked on the super 88 again. I'm getting smoke but it doesn't start. Probably a good thing because it has diesel in the oil. Previous owner put an electric pump on it and it has not ran since. I accidentally left the pump on yesterday. I'm not sure if the diesel got in the oil from the original lift pump or leaking past the injection pump. Is there a way to tell before I refill the oil? Thank you Paul
The original has been taken off. Maybe I will run the electric pump with the oil plug out and see if anything comes out. Would it be the two large O rings on the head that need to be replaced or would it leak past somewhere else?
