Part Time Pete
- Location
- Leatherstocking Region NY
As I posted below, I screwed up and didn't time the injection pump before I pulled it off the tractor. I pulled the valve cover and brought it up to TDC, and the valves on the #6 cylinder (toward the rear of the tractor)appear to be closed (one is just starting to open). Do I have the right TDC? I've attached a picture.
The screw up may have been a good thing though - if you look in the picture, you can see that a section of the rocker arm oil line had broken off
Thanks
Pete
Thanks
Pete
