Buda cylinder head studs
Mike(NEOhio)
Location
Newbury, Ohio
I'm putting the head back on with new gasket (230 gas). Should I screw the studs into the block till they bottom out or back them out a little? I had the head on loose and the stud ends don't go all the way through the nuts. Maybe I'm splitting hairs here but it's a long time since I tore it down. Don't remember.
You want the studs to come through the nuts a little bit. Make up a gauge or use a combination square so you can set them all to the same height!
