Super 55 Steering parts question
Jakeh9890
New User
Okay so I posted a while back about not having any steering on my super 55. I finally got the steering box off and apart and and as someone said on here it's definitely the steering shaft bearings. Does anyone have a NAPA part number for these bearings or a place I can get them online? Also I think I need a steering shaft because the worm gear on it is pretty chewed up and I'd rather not put this whole thing back together and end up having that being a problem.... the other thing I noticed and I'm not sure if it's normal or not is the part that the steering shaft screws into is very loose and I can just slide it up and down the steering shaft so I'll post a couple of pictures and see what you guys think. Thanks alot in advance
If you cannot find the bearings and cups. I believe I can find them. E-mail is open....bottom right classic view.
Wayne
I don't think you'll find those at any auto parts store. I took a new bearing and the box to the local Parts Plus and they couldn't match it. You'll have to get them from Agco. There's no inside race in those bearings,just a cage and rollers.
(quoted from post at 07:10:47 02/22/18) If you cannot find the bearings and cups. I believe I can find them. E-mail is open....bottom right classic view.
Wayne
Any idea about the shaft and the fitment?
Ya,Kent Gordon in Palestine Texas. He parts Super 55s and 550s. Number is nine O three,7298349.
You should be able to get the bearings from this site. 8N3571-OE bearing, 8N3552 cup Ford numbers. MF numbers 180549M1 bearing, 180526M1.
Buddy
(quoted from post at 20:06:08 02/22/18) You should be able to get the bearings from this site. 8N3571-OE bearing, 8N3552 cup Ford numbers. MF numbers 180549M1 bearing, 180526M1.
Buddy
Thanks for the info but I'm going to be exchanging mine out to count for a refurbished unit. There's more parts that need to be replaced then it's really worth dealing with.
