Injection pump throttle shaft seal
dnd
Hi everyone,,, starting spraying corn today with the Super 77 diesel,, half way through the first 15 acres diesel fuel was leaving out the throttle
shaft on to the frame... I think this has been asked numerous times on here,, but is this something I can change or do I need to remove the
pump and take to a shop? Below are pictures on the rig I?m using along with a close up of the pump,,, Thoughts suggestions... it seems to run
ok, just want to get this fixed before it get to bad,, we are suppose to have rain the next couple of days in west central Wisconsin. So if anyone
can help I can pick up a seal tomooorw and possible get it swapped out over the weekend between grad parties and my annual honey do list of
planting flowers 😀😀😀🚒
That is a Z pump! That pump was not on that tractor when the pump was new. You will need to remove the governor and replace the seal and both bearings and maybe the shaft as well. A 7/16 quarter inch drive socket works wonders. Send em an e-mail. Include your phone number. J.
