1750 Tie Rod Part No.
pcrh
Hi:
I need to replace the inner tie rod on our 1750 Cockshutt tractor. Does anyone have a part number which could be used a Harbor Freight or some other parts store?
Thanks
There is more than one. Will need some dimensions. Also do you have an adjustable or nor adjustable front axles? A serial number would be nice as well. J.
Hi J:
Sorry yes you will need more info.
Solid axel (wheatland i believe) Serial No 198 209 427 and Model No 375 42008 for tractor.
I have not taken the tie rod apart so I do not have dimensions. If I am right the Agco part number for the tie rod assembly is 106674AS, but I just need the inner tie rod.
