Oliver 1650 3point stuck
I Have a Oliver 1650 and the 3 point is stuck in the up position. I heard that there is a pin or rod stuck causing the pressure to not release. Is that a tough job to fix. Any tips before I crack it open and or part numer for that pin. Thanks
May need to reset the link to the draft sensing lever. Or take the pin out and rotate it all the way to the rear and see if it will lower. Check the lift arm free play, too.
